changing intake
Old Mar 21, 2013 | 09:43 PM
SSdreamz's Avatar
Default changing intake
I currently have a 383 with an LS6 intake and stock TB making 471/467. I am picking up a used, slightly ported FAST 90mm intake paired with a NW TB. will i need a new tune making this change?
Old Mar 22, 2013 | 01:01 PM
SSdreamz's Avatar
bump to the top
Old Mar 22, 2013 | 02:04 PM
outkast6991's Avatar
It should be retuned but it will run and drive. Stay out of WOT, it will be lean
Old Mar 22, 2013 | 02:39 PM
sweet-94z28's Avatar
It may also idle odd or start hard as well. It just depends on the current tune and the ability of the computer to adjust the IAC. I would put it all on and if you have a scanner that reads IAC position, try to get the IAC position to 40-60 at hot idle by adjusting the TB blade screw. That will help it idle better, start better, and it may also help your tuner.
