2 bar map question
Old Mar 31, 2013 | 04:18 PM
massconfusion's Avatar
Default 2 bar map question
Ok i tried searching this but didnt get too much. I ve a 2 bar map on my sd tuned turbo 5.3l. I got a little over zealous on the boost controller and hit 17psi. previously i had never gone over 15 psi and didnt think i could given the fact that i have a 7 lb spring. Car ran great so i m curious how if i was outside the map range why the car still ran good. Also is it real dangerous to creep a little outside the range when i hit the track? Thanks guys
Old Mar 31, 2013 | 05:38 PM
MUSTANGBRKR02's Avatar
You can push as much boost as you want but the two bar MAP limits how you can tune over that KPA. There are ways to scale and tune around it. I ran 18lbs on a two bar for awhile but have now stepped up to a 2.5 bar.
Old Mar 31, 2013 | 09:13 PM
got-a-ls1's Avatar
it will just use the last table in the 2 bar ve table. i was running 18-19 psi with my 2 bar no problem.
Old Apr 1, 2013 | 01:41 PM
Cool. I might start pushing the limits this year at the track lol. Now I just gotta ditch these 4.10 gears so this bitch can run!
