Auto harness & PCM work with an M6?
Old Apr 6, 2013 | 06:26 PM
the1theycallthe1's Avatar
Default Auto harness & PCM work with an M6?
So i've bought an auto setup, harnes & PCM. But it's going to be in a car with an M6.
Will it work & what do i need to change?
Thanks!
Old Apr 8, 2013 | 04:54 PM
bumpity
Old Apr 8, 2013 | 10:31 PM
Pacer Racer's Avatar
If you don't reflash the pcm with a stick shift tune, you'll have a lot of DTC's.
You will not have reverse lock out or skip shift.
You might have some idle issues, since it will not see the clutch switch or when the car is in neutral.
You'll need to get the VSS connector to fit, I'm not sure that they're the same
Old Apr 9, 2013 | 08:11 AM
Excellent - that's some good starters. Thanks for your help.
