Russ K Idle Config
Old Apr 14, 2013 | 09:33 PM
badazz81z28's Avatar
Default Russ K Idle Config
I must say, pretty cool scanning tool for Base RAF
Anyone know how does it works??? It said my BRAF should be half of what it is set to now. Interesting.
.700 according to the config and mine is at 1.350
Old Apr 15, 2013 | 07:43 AM
sweet-94z28's Avatar
Does your idle hang at times? Mine was bad until I used his config to get it dialed in. I set timing to reasonable levels for my cam, then I adjusted the BRAF values to what his calc suggested.
Old Apr 15, 2013 | 08:48 AM
Yes, is BAF the only thing you changed and it went away?
Old Apr 15, 2013 | 01:51 PM
That and making sure that your timing is smooth. I set closed throttle park and neutral timing/ in gear timing very close to my high octane and low octane timing in the low RPM and low airflow areas. Remeber to log from cold to hot and record the values.
