advise on where to start correcting tune issues
so to start out, i'm running extremely rich. would anybody advise on my first corrective actions? should i be looking into my fuel management? disable flex fuel commander from reporting to the computer? other?
i also have captured the current tune on the truck if anybody needs to see that file to help out.
Might want to get the number off of an injector and look up the flow and make sure it's right in the tune.
After getting the base tune correct to start, then I would proceed to tuning VE table, if my fuel trims were high.
Edit, after reading back and seeing that it actually leaned out on hard acceleration, I would think the injector flow data in the tune might be for a non-return fuel system and perhaps you have a vacuum regulated fuel rail. If that is the case you need to set the injector flow the same across all MAP values. Again, see tune repository for non-flex vehicle.
am i right to switch tan on the wiring? those pin numbers you gave me are for forward o2 sensors correct?
This may help you with identifying your wires. (Obviously this is for F-bodies, but seems as if your wiring/ecm is very similar) A lot of us F-body guys switch the wires so we can do without buying extensions and just utilize the factory harness. (Basically do the pin swap and the rears become the fronts and will reach long tube headers)
Hope this is kind of what you were looking for.
I have the o2 sensor schematic right in front of me for a 2000 silverado, I assume it would be the same as it can use the same pcm and o.s. I can e-mail you a copy if you pm your e-mail address. I don't know how to post a file.
HO2S Bank 2 Sensor 1
tan - C1-26
PPL - C1-66
HO2S Bank 2 Sensor 2
Tan - C1-25
PPL - C1-65
Added; Bank 1
HO2S Bank 1 Sensor 1
Tan - C1-29
PPL - C1-69
HO2S Bank 1 Sensor 2
Tan - C1-28
PPL - C1-68
next up.....
my ecm came from a flex fuel vehical and my truck is not. i have dissabled the codes i was getting about the modual not communicating. my next question is on my stoich afr commands i get a % table with afr commands per ethanol %. should i change this table to read same value across all cells since i don't use blends above 10%? this is how i see most tunes in repository that are non flex fuel.
next up.....
The way I understand it, the ECM will use data received from the o2 sensors to trim fuel until stoichiometric ratio is acheived, no matter what the fuel is. It is 14.7 for gas, 14.1 for e10. The o2 sensors will see the same voltage at stoich for each fuel mix. It is also likely that your wideband is configured to read 14.7 at stoich for any fuel burned as long as the o2 counts are in the stoich range.
Not sure what to set stoich at, but I would start with a stock non-flex fuel value.
arithmetic for you based on EQ number. We don't have
a good idea what "up to 10% ethanol" means, practically
speaking, pump to pump. I'd settle on one you like, and
tune to lambda rather than the mystery AFR(stoich).
I've never looked at a flex fuel vehicle but wonder if, like
many modes, there's a way to just turn it off and pretend
it's a straight gas tune.
Now 12.5MPG in mixed driving for a heavy square-nose
brick, doesn't sound all that bad; the cammed up Camaro
gives me about 15 and my 4BBL SBC 400 '70s Caprice
delivers a sweet 8MPG (no overdrive).
if so then I'm thinking I don't need to compensate for the pumps 10% label and use the factory 14.7. Is this safe? goal for me here is safe and economy.
