Fan Setting Question
Old May 3, 2013 | 10:51 AM
hcb1700's Avatar
Default Fan Setting Question
Guys, I am in need of suggestions/advice for my '00 SS. I replaced the fan with a 180* thermostat, and went ahead and did the LT1 radiator upgrade after my old radiator started leaking. My question is: What should I set both fan temperatures on for the 180* thermostat? I searched all over th eplace, but the only thing that kept coming up was people saying not to change thermostats. Thanks in advance.
Old May 25, 2013 | 07:04 AM
89 formula350's Avatar
I did a quick search and found this posted here.
________195
________ON______OFF
F1______209F____200F
________98.3C___93.3C
F2______219F____210F
________103.9C__98.9C
________180
________ON______OFF
F1______194F____185F
________90C_____85C
F2______204F____195F
________95.6C___90.6C
________160
________ON______OFF
F1______184F____175F
________84.4C___79.4C
F2______194F____185F
________90C_____85C
__________________
Old May 25, 2013 | 07:26 PM
decipha's Avatar
I always set the low speed 16'F over the thermostat temp and turn off 4-8 degrees less than the on temp
Add 10 degrees to the turn on of f1 for f2
