cam sensor testing?
Old May 18, 2013 | 02:18 PM
overhere's Avatar
Default cam sensor testing?
im running a msd6010 ignition but uses stock cam sensor so testing should be the same. getting cam sensor fail code form the ignition.
replaced sensor same problem
I have 12v on pink wire which is sensor feed.
8 volts on brown/white which is signal.
does this sound right?
thanks.
Old May 19, 2013 | 08:33 AM
donnie_19's Avatar
Look at the connector
A == Signal
B == ground = low reference
C == switched power = reference voltage = ignition = 12V
Old May 19, 2013 | 11:28 AM
62n62's Avatar
a is 5 volts from ecm b ground from ecm c is signal back to ecm on gm
