STFT tuning How to turn off pe
Old May 22, 2013 | 06:55 PM
2000 TA owner's Avatar
Default STFT tuning How to turn off pe
HP tuners how do ou turn off pe can I just bump up the cold temp to 100%
Old May 22, 2013 | 07:19 PM
ctd's Avatar
ctd
Why do you want to turn off PE?
Old May 22, 2013 | 08:28 PM
thats what it tells me to do to dial in my stft disable ltft and turn off pe to log my histgrams
Old May 22, 2013 | 08:50 PM
Bowtie316's Avatar
Just change the enable map kpa to 640. That's what I do.
I also don't worry about disabling LTFT, I just copy both histograms (LTFT and STFT) 1 at a time and paste special-multiply by percent.
I often worried about if having PE disabled could cause a piston meltdown or anything but I believe since the extra PE timing isn't added it should be fine. Either way, I don't stay in the high load/high rpm areas for long without letting out.
Old May 22, 2013 | 09:17 PM
ctd's Avatar
ctd
What tells you to disable PE? If you are tuning the STFT's correctly you are never near PE.
Turning off LTFT's is fine if you know why you are doing that & how the work, do you?
Old May 23, 2013 | 07:27 AM
Bowtie316's Avatar
The method for STFT tuning in the "how to's" in this forum say to turn off PE. The reason for this is because the pcm stops using fuel trims when it enters PE.
How could you ever get the VE table correct for cells that are generally in PE if you didn't disable PE?
Old May 23, 2013 | 02:26 PM
ctd's Avatar
ctd
OK, do it your way
Do you really want to tune @ Stoich when you should be in PE, isn't that hard on motor's? Yes the VE & MAF tables will tune just fine, same as if you set up the entire tune to run OL.
Old May 23, 2013 | 03:07 PM
Bowtie316's Avatar
Well i was actually asking how, because I have never tuned that way, do you get the base VE tuned if you have PE on? I would assume you would have to set the tune to open loop, the create a histogram with comanded vs actual afr on a MAP vs rpm table? I haven't got that far yet.
I often wondered, as I mentioned earlier in this thread, if it is hard on the motor. I came to the conclusion that it is probably not since extra timing is not added, but I still try not to stay at high load/high rpm cells too long without backing out.
Actually running OL scares me more because you would have to spot an issue and back out prior to damage whereas in closed loop the PCM makes corrections much faster than I can.
I am new to tuning and am by no means an expert, just trying to help the OP out with the question asked.
Old May 24, 2013 | 09:04 AM
ctd's Avatar
ctd
I would never tune with the PE turned off, you need fuel when you start loading the motor. So don't load the motor if tuning OL scares you, get someone to help tune Hi Load & WOT area's.
For you idle, part throttle & cruising condition's you can tune using the FT's quite nicely. If you are really out of wack with your combination start with STFT + LTFT's that will give you a 50% window.
Old May 24, 2013 | 10:23 AM
Bowtie316's Avatar
See, this is what I'm not sure about. The stickied how-to on this site says to do it this way. I am going to start a new thread "CLICK HERE" because this has been on my mind lately and I don't want to crap in this thread anymore.
I agree with this fully, however, I continue to the higher rpm/load cells as well.
Old May 24, 2013 | 02:46 PM
BLK02WS6's Avatar
https://ls1tech.com/forums/pcm-diagn...-disabled.html
