Reasons why ECM wont send start voltage to relay.
Fixing a flood dammaged car. New BCM/ECM/VCIM, Questionable Contacts have been cleaned or replaced. When turning the key, the relay on the BCM relay clicks, but no cranking.
Just shooting for ideas, only thing I can think of off the top of my head is maybe a bad clutch switch, which i'm going to check tomorrow.
Most things are working correctly in the car as of right now, lights, gauges, etc etc. Just not cranking, and when I say not cranking its not the starter. The ECM is not sending the signal to the relay.
