Crankshaft position sensor replacement
Old Jun 21, 2013 | 09:36 AM
Nicky98T/a's Avatar
Question Crankshaft position sensor replacement
My friend has an 2005 GTO, the other day while driving his car just gave up on him when he got to idle. He threw a code and it was p0356 (CKP) we installed a new sensor along with a new camshaft position sensor (only way to get the car running) He drove it home last night and it was fine, this morning he attempted to start the car and it only cranked. He than shifted the car into neutral and the car started. Now the car wont start again... Would anyone have an insight on this?
Thank you
Old Jun 21, 2013 | 12:00 PM
topgun542's Avatar
Check The Wires At The Connector For The Crank Sensor. Just Throwing Ideas out
Old Jun 21, 2013 | 01:05 PM
Nicky98T/a's Avatar
we did that the other day, now i mean we could check again... but my question is can this all be happening because it needs a relearn?
Old Jun 22, 2013 | 03:20 AM
joecar's Avatar
Sounds like there is too much crank end play (crank thrust bearing worn).
Old Jun 22, 2013 | 05:51 AM
MontecarloDrag's Avatar
No.
The car has another issue. Since it threw a code last time it may have a broken wire
Old Jun 22, 2013 | 06:15 AM
Nicky98T/a's Avatar
The car has 20k on the clock...I have voltage at the harness checked for frays burns kinks anything almost 3 times its driving us crazy
Old Jun 22, 2013 | 06:56 AM
Old Geezer's Avatar
Lightbulb Maybe...
Follow up on Joe's suggestion???
