Dynotune problem torquer v2 cam
Old Jun 26, 2013 | 09:35 PM
WS SIK6's Avatar
My builder said that he gapped my spark plugs at .35(ac delco iridium)and I told the tuner and he said it was fine, can that be what's causing it?
Old Jun 27, 2013 | 08:22 AM
WS SIK6's Avatar
Anybody care to post their opinion if the gaping on my spark plugs(.35) could be what's causing my problem?
Old Jun 27, 2013 | 01:18 PM
salemetro's Avatar
What code is it throwing? Gap seems a little tight...I prefer .045 on a non-N2o build.
Old Jun 27, 2013 | 09:36 PM
MontecarloDrag's Avatar
The gap is not the cause, however you need to use a wider gap, 0.045" to 0.050" works good
There is something funny going on. If the car runs good for a while then starts acting up, you have more problems than just the tune. You need to do a datalog when the problems are present to find what is the cause.
I have tuned a few cars with the same cam you have, all of them had stalling and surging problems. I found those cams like a lean AFR and a few more degrees of timing to idle properly. They work better in open loop if the engine has LT headers but CL is possible.
Old Jun 27, 2013 | 11:12 PM
WS SIK6's Avatar
I'm actually gonna check what code it's throwing right now I just got home from work, and I'm gonna open up my spark plug to the recommended .45 and I will see how that goes!!
Old Jun 27, 2013 | 11:45 PM
WS SIK6's Avatar
Alright so I just scanned my trans am with my little brothers diablosport and here's what it threw at me:
Fault 1of 1
P0106 manifold
Absolute pressure
Range/performance.
Any idea what that means guys?? Thanks!
Old Jun 28, 2013 | 04:01 AM
Fault 1of 1
P0106 manifold
Absolute pressure
Range/performance.
This can be fixed with tuning. I need to see a datalog from the car to be sure, but it seems the engine is making very low vacuum and it's tripping the code.
Under engine diagnostics there are 2 tables you can adjust to avoid this.
Drive the car a little more to see if it also trips a P0121
Old Jun 28, 2013 | 08:01 AM
WS SIK6's Avatar
Ok I will drive it some more to see if it throws the p0121 code, and I was also reading that it can be a problem with the map sensor, so I'm gonna take the car to my builders shop this weekend and have him give it a go at my problem
Old Jul 1, 2013 | 01:35 PM
SSpdDmon's Avatar
Sounds to me like he doesn't know how to tune for drive-ability and idle that well. Getting numbers at WOT is pretty easy in these cars. But, getting a full tune and getting it done correctly is what separates the men from the boys......that is - assuming the car is mechanically sound (no vacuum leaks, exhaust leaks, etc.).
Old Jul 12, 2013 | 12:43 AM
WS SIK6's Avatar
Went my my tuners shop yesterday and not my ses light doesn't turn on anymore, he checked everything on my car, sensors,vacum leaks etc...and he said everything is fine...he adjusted a few things for about an hour and it drives a little better now and won't always die at idle now....but now if I rev te engine at idle the revs will stay at about 1400 rpm's for about 10 seconds then start decreasing....I really don't know what to do anymore, I'm getting kind of frustrated driving back and forth just to end up with the same problem?????
Old Jul 12, 2013 | 12:59 AM
itsslow98's Avatar
Who is the tuner?
Old Jul 12, 2013 | 11:49 PM
  #32
WS SIK6's Avatar
I don't really want to throw them under the bus because they're really good people and they have tried to do everything to help me with my car but they just can't get the tune right, I don't have anything bad to say about them personally they build and tune some crazy machines but they're just having a hard time with my tune.... It's RPM MOTOR SPECIALTIES in Santa Clarita, Ca
