6L80 T43 Operating System Question
Old Jul 2, 2013 | 12:52 PM
1989GTA's Avatar
Default 6L80 T43 Operating System Question
As some of you know I erred when I mated an L92 out of a 2007 Escalade to an unknown 6L80 transmission. I now have a communication problem. So I ordered HP Tuners so I can scan the transmission to see what operating system is in it and possibly the VIN#. Some say it won't show the VIN#.
This is the question. If the transmission turns out to be from a vehicle that was made in 2009 would it be possible to use a E38 ECM out of a 2010 L99 Camaro? As I understand it the 2010 Camaro still uses the older transmission code. That would be my ideal situation and best way for me to get out of my problem.
Edit: IMHO the transmission is most likely out of a 2008 or 2009 vehicle.
Old Jul 3, 2013 | 06:11 AM
rsz288's Avatar
The trans has a 4 character code on a sticker on the RHS of the trans. Like 8CVA. 8 is the year. 9 for 09. 0 for 10. 1 for 11. etc. Likely work with the Camaro ECM but if not a matched pair then possibly may not run as they would if they were a matched pair.
IIRC HPT does not show the trans VIN.
Old Jul 3, 2013 | 11:20 AM
1989GTA's Avatar
Thank you for the information. I will try and get under the car and look at the transmission for a code. I have a picture of the left hand side and of course it does not show the code. I didn't think HPT would show the VIN#.
Old Jul 3, 2013 | 11:38 AM
1989GTA's Avatar
Update. With the information provided I found the code and it is OCAA. So that would mean a 2010 transmission. Thank you so much for the info. Now for some more detective work.
Old Sep 9, 2013 | 03:35 PM
TrueBlueGTO's Avatar
FYI for others. They key is the top level series of numbers to the right of those 4 digits. Those numbers usually start "242xxxxx" and will tell you the specific TCM inside and the vehicle plotform it came out of.
