Will someone look at my HP tune?
I've attached my tune file from a dyno tune (only hour worth) I occasionally have a rolling idle issue where if i'm rolling no matter the speed sometimes it will be fine other times it revs all the way to 4k and hangs there till I come to a complete stop for about 5 seconds then drops to normal. This doesn't happen all the time usually after I start it up first time in 5+ hours it will drive fine then if I shut it off and restart it it will do the rolling idle issue. Any advice on what I could change to maybe fix the issue? List of mods bellow sorry it was easier to copy and paste everything
2001 Camaro SS M6
Pacesetter 1 3/4 headers
walbro 255 lph fuel pump
new rings, crank and rod bearings
ARP Rod Bolts
QTT cam 232/236 .601/.601 112 LSA
Lunati Lifters
TSP 7.4" hardened push rods
Cloyes billett timing chain
Ported LS6 oil pump
MLS head gaskets
.241 head casting milled .010, valve job, bowl and throat blend
PRC dual valve springs .675
LS6 intake
fast 42lb injectors
all new engine gaskets and sensors
ls2 style starter
spec stage 2 clutch
motive 4.10 gears
rear end rebuilt with Ratech bearings
2001 Camaro SS M6
ARP Rod Bolts
Lunati Lifters
Ported LS6 oil pump
MLS head gaskets
LS6 intake
fast 42lb injectors
ls2 style starter
spec stage 2 clutch
motive 4.10 gears
i found his config file after car cools down i'll try it. this wont effect my running rich at cold start up and almost causing the car to die when i give it throttle. does anyone see something i'm missing and should adjust anywhere?
