Frustrated plz help!!!
What did you put the intake and tune on?
What o-ring is leaking, injector to manifold? Vacuum leak?
Car was running 13.7 when? during wide open throttle? And how are you measuring it?
The oring injector to mani.
And the car ran 13.7 before I added intake and headers wot at track. With headers and intake untuned 14.7 wot
If those are track times, I think you might have an injector (#8 likely) unplugged or malfunctioning. Does the car run clean and smooth?
I don't think people usually slow down when adding intake and headers, but they won't gain much without a tune. I suspect something is wrong at this point.
You must get the intake leak fixed before going any further.
With a vacuum leak, the computer will have to add fuel trims to compensate and is probably dumping a lot of extra fuel during wide open throttle because of it. Also, need to figure out the cause of the misfire and get it fixed.
