why didnt it pull timing?
Old Jul 17, 2013 | 04:51 PM
bad6as's Avatar
Default why didnt it pull timing?
wondering if i have a setting wrong. at 1.20 g/cyl at 104* it should pull one degree 5* at 149* and 6* at 167*
if you look at my low octane timing table the 1.20 g/cyl is 15* from 4000 rpm and up. as you can see the iat got up to the mid 170s
on the scanner on the chart i have timing advance as the sensor that im logging. is that the actual timing value the motor is using at that time or do i need to reccord timing retard to see the timing being pulled
File Type: hpt
File Type: hpl
Old Jul 17, 2013 | 05:27 PM
Bowtie316's Avatar
It looks like it's adding timing in those cells from the afr spark correction table, looks like it is almost enough to cancel out the iat deduct, but I didn't do the math in each cell.
It shows you are commanding 1.18 in PE, is that right? It just seems low for boosted vehicle.
Old Jul 17, 2013 | 07:21 PM
bad6as's Avatar
I use alot of meth. And no i/c
ill look into the afr spark correction
