2 step function with BS3 and a T56?????
Old Jul 18, 2013 | 10:27 AM
RAMPANT's Avatar
Default 2 step function with BS3 and a T56?????
Looking for any help that can be offered using the 2 step in BS3 with my T56.
What I want will not be the typical or simple, but there has to be a way, and I am hoping some one has done it before.
What I want to have for function, is a 2 step that I can arm, and then floor it and then upon dropping the clutch it will be disabled till it is re-armed. So I want it to only be able to function once.
I do not want a push button on the shifter or steering wheel.
I want it for drag racing and I think it could be used for launching off the line at an autocross where I will be shifting up and down after the launch, so I do not want it reactivating if I go into 1st.
So I am thinking I will need a solenoid that can get a signal from my arming switch, then maybe be deactivated by a micro switch on the top of travel of the clutch. Not sure how this would wire up though.
Thanks in advance for your thoughts.
Old Jul 19, 2013 | 05:41 PM
flame's Avatar
You may be able to use the clutch anticipate switch that the cruise control uses at the top of the clutch pedal travel. I'm not familiar with bs3 though to know how to set it up.
