pcm got locked up how can i unlock it?
how can i get this fixed?
can anyoen explain what happened?
I'm guessing It hung after 50%?
I had a similar incident happen to me 2 years ago... I was flashing my PCM and for some reason the software lost connection to the PCM (it was either low battery in the car or a problem w/my USB to Serial adapter) ... car wouldn't start after
I ended up having to have my PCM reflashed at a dealership w/a Tech II
The PCM is like a computer... (well it IS a computer) ... when you turn the key on it boots up (which is why it says to leave the key on for 10 seconds) ... once booted Edit goes out and clears the PCM and then writes the new Flash onto to PCM... if you loose connection during the write, the PCMs Operating System is complete so the PCM doesn't know how to boot up...
HP Tuners has built in recovery for this... but with LS1 Edit there is no such feature
So best bet is to have a dealership reflash the PCM
