Need OBDII/ timing gurus please......
With a Wideband you can get a better look at what's occuring.
joel
It would be nice, but $$$. My tuner said that the computer only uses the VE table for cranking since it says "Cranking VE" I believe. I thought about getting the HP Tuners tuner and going at it myself.... Its just all those formulas for VE are intimidating
So... If the VE is way off (and Im sure it is) it can cause the problems I have?
Yes, with a big cam it will cause the problems you have.
http://automation.slowcar.net/
Where can one get ChrisBs Logfile Analyzer? Thanks for the help Bink
joel If you think it might be the cam/crank sensor you can usually watch the rpm and when it starts doing it the rpms will be erattic too. Also watch for false KR
