showing code P0101
Old Aug 2, 2013 | 11:36 AM
chm2001z's Avatar
Default showing code P0101
my car is speed density tuned but it has been throwing this code lately. I cleared the code and it appeared again after 60 miles. I thought the maf was turned off when tuned. I don't know much about tuning so I apologize if this is a stupid question but why would it be showing the code?
Old Aug 2, 2013 | 03:02 PM
LSX Power Tuning's Avatar
Are you getting a check engine light for the code or is it just showing up when you scan the car? With the MAF turned off for SD you will see a P0102 if you scan it but you shouldn't get a check engine light for it.
Last edited by LSX Power Tuning; Aug 2, 2013 at 04:05 PM. Reason: typed wrong number
Old Aug 2, 2013 | 03:16 PM
Russ K's Avatar
Failing the Maf in the tune will set off P0103, and unplugging it will cause a P0102. So your not in SD mode, and the P0101 is caused by a large difference between the Maf calculated airflow and the speed density calculation.
Russ Kemp
Old Aug 2, 2013 | 04:05 PM
Russ Kemp
You are correct, its P0102 not P0101 if the maf is unplugged. I'm going to edit my previous post with the correct number.
Old Aug 2, 2013 | 09:55 PM
chm2001z's Avatar
the check engine light comes on and when I clear the code it goes off.
