P0336 and car not starting
Upon the searching I did before the code P0336 has to be reset with a tech 2 tool.... tried running the scan with an "Actron" scan tool. Which is supposedly the generic version of a Tech 2. I cleared the codes but the car still won't fire....
Any ideas/suggestions?
Check the wiring from the crank position sensor. Especially since you said there was smoke from under the pass floorboard. That is the approx location of the CPS. It is above the starter.
I was able to connect to the PCM with EFI Live, so that, in theory, means the PCM isn't shot....
EFI Live Pro can supposedly do the CKP relearn, since it has the bi-directional controls. A friend of mine is coming over later to see if we can do that. If not, gotta get it to the dealership for them to use the Tech 2 on it.
