hptuners 1st full throttle try
Have yet to wire in my wideband, figured I'd do a pull to see what the car is doing stock. It's at 22:34. Had a bit of knock in 1st, didn't rev the **** out of it, timing stayed below 20 degrees of timing while on the throttle hard. Anything painfully wrong looking at this? I ordered the master efi tuner book, probably won't change much till I put headers, y-pipe etc on.
EDIT:looked at the histogram, appears the car is using the low octane table? Running 93
