HP Tuners & 98 PCM- locking conv in 3rd gear @ WOT ??
HP Tuners gurus, I have a question.
Can HP Tuners lock the torque converter clutch in 3rd gear at wide open throttle? I want to make some nitrous passes and lock the converter in 3rd gear around 100mph. Not exactly sure how to do it.
Running a 4L85E with FTI triple disc converter on a 4L60E tune ("slow67" relay mod) on a 98 F-body PCM.
Just not sure what to do with the TPS release tables that say if 100% throttle opening is reached the TCC will release, is there a way to override this command?
Thanks in advance
Thanks in advance
