Need some Help - 427 LSX drop in motor 2002 Transam
Old Sep 9, 2013 | 06:54 AM
Patsy57's Avatar
Default Need some Help - 427 LSX drop in motor 2002 Transam
Hello I have a 2002 transam WS6 with a Cam that is putting down around 410hp at the wheels with a cam. The car right now is tuned, and I want to drop in a forged 427 LSX motor with FAST 102 that will have a Procharger on it later. The only issue I have is that if I swap motors my PCM will have the old tune on it for the NA Cam. The new motor runs at 9:1 and while i wont have to drive it much at all while she waits for the procharger and a tune from RPM, she will still need to be driven from the mechanic to my home.
My concern is by changing the motor to a completely different unit I run the potential of running lean and god for bid seizing the motor. What can I do? I do not know enough about HP tuners to feel confident in tuning the car myself.
I was planning on using stock injectors until she gets the procharger but i am not sure if that will hurt the new motor.
Anyway please let me know your thoughts. Unfortunately for me everything is far so I need to get the motor in the car get her home, have her sit a few months just starting her and taking her around the block etc. Then when winter is over get her and the procharger shipped to RPM and have them installed and tuned. Also will need to replace my fuel system which lonnie will do at that time, for the initial swap I will use my factory lines and pump.
Thanks!
Please let me know what you think
Old Sep 10, 2013 | 09:22 AM
Patsy57's Avatar
bump... anyone?
Old Sep 10, 2013 | 10:35 AM
LSX Power Tuning's Avatar
Your going to need it re-tuned before u drive it. A mail order tune could get you up and running.
Old Sep 16, 2013 | 03:55 PM
Patsy57's Avatar
As a follow up I dont think my stock injectors will work so what injectors would you guys suggest? 60lb? Its at 9:1 compression now
Old Sep 16, 2013 | 04:11 PM
codyvette's Avatar
The guys at the injector store you choose will be much more suited to answer this question. It hinges more on horsepower and boost than it does on compression.
Old Sep 16, 2013 | 04:18 PM
Patsy57's Avatar
I hear you but to get it to the shop it needs to run, and swapping an ls1 for a 427 lsx motor will require bigger injectors to run it to the shop. These injectors would be only for NA and the motor would have a base tune on her.
When I add the supercharger then I would have the tuner answer it for me.
As of now I'm just looking for info in relation to the swap of the ls1 to the 427
Let me know your thoughts
Old Sep 16, 2013 | 05:26 PM
Frans96SS's Avatar
Give us a call. Ill get you set up. We can give you a base file for whatever you need.
Old Sep 16, 2013 | 07:13 PM
Patsy57's Avatar
Fran,
Sent you a few emails asking what you needed to do this, havnt heard back yet. Please PM me, my motor is being broken down now, once its all apart and i have all the specs on it (bought used) i wont have the info. When its all done I need to get in the car and have it run until I can get it down to you with the blower.
let me know
Thanks
Pat
Old Sep 17, 2013 | 03:11 PM
Patsy57's Avatar
Ok so if my motor has a 58x reluctor ring and all the correct sensors in it, then what would I need to change in my 2002 WS6 transam chassis? the PCM?
Old Sep 17, 2013 | 10:47 PM
You'll need a lingenfelter box for the crank signal, need to also change the map sensor, knock sensors, couple other little odds and ends but thats most of it.
Old Sep 17, 2013 | 11:42 PM
Patsy57's Avatar
So even if the motor has all the right sensor for a 58x reluctor ring and the PCM is upgraded to match as well I still need that box?
Old Sep 18, 2013 | 05:02 AM
sicksspeed's Avatar
Your car has a 24x operating system (computer) the motor is 57x. You either get the conversion box or pull the crank and swap the reluctor. Swap is a lot harder but more reliable in the end.
Old Sep 18, 2013 | 06:47 AM
Patsy57's Avatar
I get that and that's what I'm saying, if I swap my PCM can I use the 58x reluctor? And what needs to be in the car to use the 58x reluctor?
Old Sep 18, 2013 | 09:49 AM
Your car will not run a 58x pcm, you cant just put a different pcm in it and it work. In order to run a 58x motor in your only 2 options are 1) lingenfelter box 2) pull crank and change reluctor wheel to 24x.
