Which EGR wire to hook AEM Wideband to?
http://download.efilive.com/Tutorial...20Tutorial.pdf
The fuel pressure sensor lets you monitor your fuel pressure. I have a fuel pressure sensor mounted to the fuel rail and I use the EGR signal wire to read the fuel pressure sensor through the PCM and into EFILive when logging.
I was referring to the fuel tank pressure sensor. My bad.
What exactly does the tank sensor do and can I do a way with it.
Race car only.
Thanks
I took the evap off at the tb.
But I think there's one at the fuel tank also.
Could I get rid of the fuel tank pressure sensor and the
Evap at the tank?
