New mod? = SES..." help"
and I P/P T.B.
Perfect night for racing 40% humidity and upper 50's temp's
So first pass. 13.81@101.2 w/2.06 60'ft
next pass 13.72@ 102.4mph w. 2.15 60'ft
during second pass SES light came on. So I left track knowing something is wrong.
Last time at the track I ran 13.07 and 13.08 back to back hot lapping on a 70% humidity upper 70deg day.
Get home and scan code p0131 02 sensor low volt bank 1 sensor 1
02 reading 0.09-0.11 does this seem correct?????
would this pull timing and make it slow. drove 20 miles home and seem to run fine with plenty of power. I even drove 500 miles to LS Fest with P/P TB with no issues
Did I getting to much air from SSRA lean it out??. Or vacuum leak??
I did not change TB gasket when I removed it. Vacuum line from TB to intake looks good.
Or do I have a bad 02 sensor? What should a good 02 read??
any advise would be very helpful
Thanks "mods in sig"
Cleared codes and did some WOT pulls and data log.
P0131 & p0151 showed up. I only had p0131 yesterday. Bank 1& 2 sensor 1
Was reading 0.02- 0.92 02 voltage.
Is it possible port and polish tb can lean out 02's
Im way over my head when it come to tuning
Looking at log file WOT was 0.04 for both 02's and 0.92 as soon as i let out of throttle.
I replaced TB gasket and vacuum hose from TB to intake and still throws p0131 & p0151. it hasnt thrown a hard fault SESlike yesterday, but when I scan it is there.
only does it when i pull WOT pulls.
What would lean out a 02 sensor 1???
Will a Diablo read fuel pressure?
OOH I replace a fresh air line. Well that make sense.
I did have a very low tank of fuel when I was at the track. I dont know if i was just freaking out but I could have sworn it sounded like the fuel pump was louder on the way home from track. I didnt notice that today.
So is 58psi constant pres.?
So it makes sense if im putting a ton more air into engine (ie p/p tb and ssra) and maf is reading it and trying to adjust fuel trims but pressure is insufficent.
If the MAF was bad it would give a diffrent OBDII code?
Car seems to run fine. I have been beating the **** out of it today and it pulls like crazy. But the 1/4 mile time and SES tells the real truth..
Today I changed fuel filter and put some fuel system cleaner in.
Data log showed 0.03mv @ WOT on both banks 1&2 sensor 1. And throw codes again.
Cleared codes and drove home and drove it normal and not going WOT. checked codes and none were there. So it only throws codes at WOT
I work for a car dealership. I willl talk with a couple of techs to see who has a gauge that will hook up to the rail.
I was seeing 0.15v at idle. It would jump all over the place. Highest i saw was 0.89. Does this seem normal?
Russ Kemp
Fuel pressure 60 psi at start up. Wot first gear pull. Psi38# 02's drop to .05
Unpluged maf while logging for
Second pull wot 1st thru 2nd gear. 35psi thru 2nd gear
02's start at .87 then drop quick to .06
So fuel pressure is to low. Pump going bad?
Russ Kemp
Sucks I have to do a fuel pump and racing season weather is perfect right now.
I better go shopping and see if I can pick up a pump.
Do I have to drop the tank to put pump in??
Thanks again I will update when pump install happens.
