p0343 and out of ideas
I checked the wiring (Nelson racing stand alone harness) back to the computer and had good continuity. It has 11.9v to the sensor. got a new sensor and tried again and got the p0343 again immediately. Cleared it once and then got the same code along with p0342 for low voltage...
So I figured the cam bolts were backing off even though I was sure they were torqued right with thread locker. Pulled the motor apart today and everything was good. The timing set is a jp racing single roller that I have used on other cars with no issues so I don't think the gear is made wrong...
So I'm out of ideas. Is it possible something in the tune could be causing this? The computer was base tuned by RPM for speed density. The computer was the one in the running and driving with no check engine light truck the motor came out of so I'm pretty sure its good...
Any other ideas for where to look? I'm sitting in the garage staring at this heap and can hear the guys tearing up the local 1/8 mile
Thinking it might be the cam its self or the timing set sound right?
Pulled the motor apart and found no loose bolts. Took the cam out and measured it against a stock ls1 cam and everything is identical down to the thousandth of an inch. Put a new timing set in it to rule that out. Started it today and immediately got p0343 again. After running a while p0342 came in again too. The whole time the tach continued to work perfectly though
At this point all I can think is its in the computer? Is it possible that it isn't reading the signal correctly or something got fried when the tune was loaded?
I'm really stumped at this point
The tach is wired to the tach output from the computer.
The harness is made for a rear mounted sensor and that is what i am running. The motor is a 2002...
Thought then maybe it was a wiring issue that my voltmeter wasn't picking up. Pulled the entire cam sensor circuit pigtail from the plug to pcm pins out of an engine harness I had laying around. Using that I bypassed the harness in the truck. Still got p0343...
I haven't tried shimming the sensor up yet because I didn't have anything but thick washers on hand...
That should teach me not to be such a cheap ***
Does the new sensor work with the wires swapped or un-swapped...?
I usually try to use oe stuff too but like I said before I was being cheap...
For anyone that needs a cam sensor, the duralast I got had its own part number, but it had the GM part number on the body of the sensor so I think its the same sensor but at half the price
