Any users of the Dynojet Wideband Commander?
If anyone did make it work please describe the proper method. Thanks.
And by the way I do have a shift light and NX Maximizer connected to the PCM tach signal and both units work fine with it.
All I can say is keep working the tap wire, or re-tap completely, until you get a nice 5-6v signal on the line. At that point your commander should pick it up. also, set your RPM sensitivity to HIGH in your device settings.
how abot the throttle position wire, which wire on the sensor do i tap into? and which wire would it be on the pcm?
Can you explain this more please. I am thinking aboug gettings the wbc but Im not sure what you mean. Is there a better stationary kit? Price is not THAT big of a deal
