fairly simple question
Old Oct 10, 2013 | 10:29 AM
ToxicWS6's Avatar
Default fairly simple question
ive googled this for days and havnt found an answer
basically im running hp tuners sd 2 bar OS i got all the pids in for it to go to 210kpa and all
my issues is when i go to take stft readigs to dial in VE table i get values in all the cells 105 and under, once in a while some in the 110 zone, when i get into boost the cells read where im at in MAP pressure and rpm but for there value there always 0
will STFTs always read 0 in 105-210 kpa? like is that what its suppose to do or is something wrong, thanks!
Old Oct 10, 2013 | 11:25 AM
LSX Power Tuning's Avatar
Have you changed your PE settings? When they are going to zero your most likely going into PE mode.
Old Oct 10, 2013 | 12:47 PM
ToxicWS6's Avatar
my PE mode is set to 1.0 all the way across which means normal correct or no PE?
my BE is set from 1.0 to 1.2 with steady increments going from 110-210kpa
is BE making my stft not read while in BE?
Old Oct 10, 2013 | 05:01 PM
ToxicWS6's Avatar
that solved my issue! it was my boost enrichment kicking in at 110kpa that was screwin things up, thanks!!
Old Oct 11, 2013 | 12:03 PM
jimmyblue's Avatar
Moderator
I would think that in any enrichment mode, the PCM knows
you're not commanding stoich and will not attempt to trim.
By 100kPa I'm surprised you'd see any nonzero open loop
STFTs even if open loop STFT is enabled.
Old Oct 11, 2013 | 02:04 PM
ToxicWS6's Avatar
i had 16s and 17s popping up in boost
