predator tuning problems
Old May 6, 2004 | 09:44 PM
LS1_SS's Avatar
Default predator tuning problems
hey i have a predator tuner and i got thunder racings maf ends and i dont know what i need to set my STFT and LTFT numbers too, can anyone help?? what are they supposed to be at when it WOT and when its just idle??
thanks
Old May 6, 2004 | 10:57 PM
WAHUSKER's Avatar
Don't worry about the STFTs, but you want the LTFTs to be 0 or slightly negative at idle & cruise. They should go to 0 at WOT. MAF ends tend to lean the car out, which result in positive LTFTs, but they have been known to cut up to 1/4 off your ET, so IMO they are worth tuning around.
Monitor your KR at WOT. If you are getting any steady numbers, you NEED to change something. (fuel, timing, parts)
Old May 7, 2004 | 12:47 AM
LS1_SS's Avatar
at wot both ltft and stft are 0 and at idle the ltft go like -1 and -3
Old May 7, 2004 | 08:31 AM
jimmyblue's Avatar
Moderator
Predator does not have the coverage you need
to deal with MAF ends / ported MAF. You need to
recurve the MAF table for that, you can't, only
the custom tune route will do it. Forget the ends,
especially on an A4, unless you want to go custom
tune. Go to DiabloSportTuning.com and see about
what that entails.
