Ls1 crank sensor wiring question (please help)
Old Nov 24, 2013 | 12:00 AM
7beast's Avatar
Default Ls1 crank sensor wiring question (please help)
I have asked this question on another section on here with no luck some one please help...thanks to all in advance here is the link: https://ls1tech.com/forums/conversio...ring-help.html
Old Nov 24, 2013 | 12:19 AM
2xLS1's Avatar
Attached Thumbnails Ls1 crank sensor wiring question (please help)-ckp_cmp-sensors_99-.jpg
Old Nov 24, 2013 | 12:30 AM
7beast's Avatar
Originally Posted by 2xLS1
sweet thanks for the help bud I see it now. so the A B C positions on the camshaft sensor don't go in that order. I think I see my problem now.. I will repin the connectors for sure and see if it starts.. as far as the pcm goes the pin outs should not change correct? or should I look into this also? sorry for the newb questions iam just totally new to this whole ls mess lol
Old Nov 24, 2013 | 03:29 PM
7beast's Avatar
Well today I switched the wires on the cam sensor connector to the correct spot and still can't get the engine to fire... I also tried swapping out coilpacks for the heck of it and still nothing... Anybody got any other ideas? Cam and crank sensor were in good working condition when motor was pulled from donor car... My pcm has been tuned also eliminating all vats and whatever else I don't need
Old Nov 24, 2013 | 03:49 PM
2xLS1's Avatar
Why are you swapping wires on the cam sensor. You start out asking about crank sensor wiring then start fking with the cam sensor wiring. They will run without a cam sensor signal. Will just be hard to start.
Old Nov 24, 2013 | 04:22 PM
7beast's Avatar
I started fking with the cam sensor because I also noticed that those wires were also not In he correct spot after looking at the shematic picture you posted. as of now I have the crank sensor connector and cam sensor connector all wired up according to the schematic and all the wires go to their correct spots on the pcm again according to what the schematic says. my next guess would be a bad crank sensor I suppose
Old Nov 24, 2013 | 05:25 PM
2xLS1's Avatar
Do you have a scanner? Are you getting any rpm indication with a scanner when cranking?
Old Nov 24, 2013 | 08:32 PM
7beast's Avatar
No I sure don't have a scanner but I need to Invest on one or borrow one. I don't have a tach lead either
Old Nov 30, 2013 | 08:57 PM
joecar's Avatar
Were you able to figure out the cause...?
