So fuggin mad with Edit
Old May 9, 2004 | 01:57 PM
HumpinSS's Avatar
Angry So fuggin mad with Edit
and their bullshit programming. Just killed the PCM during a flash, now I will ave to take it to the stealership to get it back up and running.
Can the stealership flash straight throught the PCM or do they have to go through the OBD2 port. Please tell me they can go through the PCM.
Old May 9, 2004 | 02:01 PM
Gen3Benz's Avatar
flashing at the dealership is usually done with a tech-2 thought the obd2 connector. tech 2 reads the calibration then you hook it up to a computer and it finds the most recently updated calibration
unless the dealership has the off-board programming harness, but most dont
Old May 9, 2004 | 02:55 PM
HumpinSS's Avatar
grrrrrrrrrrrrrrrrrr. Thanks this is just the icing on the cake for an unproductive weekend
Old May 9, 2004 | 04:05 PM
gojo's Avatar
Have you tried pulling fuses 16 and 23 with the key on and replacing them with the key off?
Old May 10, 2004 | 12:30 PM
HumpinSS's Avatar
Nope but i will make sure and try that
Old May 10, 2004 | 03:30 PM
9T9BlueTA's Avatar
Did you get an error while programming? What cuased it?
Old May 10, 2004 | 05:04 PM
Bink's Avatar
Sorry man. I know the feeling....Hotrodding at it's best!
joel
Old May 10, 2004 | 05:46 PM
HumpinSS's Avatar
THe damn thing killed my battery.
Bink
I aint to upset just because that is the nature of the beast. Hopefully all will be well in a few days and I can continue as normal
Old May 11, 2004 | 09:16 AM
HumpinSS's Avatar
got a spare PCM so i shoud be up and runing today. cam and all will be installed this weekend since i had a delay from the cam dealer
