Ecu and mass air question. Also code coming up
Old Feb 28, 2014 | 08:10 PM
STEVE PWC's Avatar
Default Ecu and mass air question. Also code coming up
Was wondering if you can run a ls1 ecu with a corvette mass air form a ls2 or ls6. Put everything together and the car is a pain in the *** to start. Once started it will run but wont stay running at 1000rpm or under. I keep on getting code po102, mass or volume air flow circuit low input. Someone told me you couldn't mix the ecu and mass air. What do you think?
Old Mar 1, 2014 | 08:43 AM
flame's Avatar
The PCM needs to be tuned for the maf
