Formula for lb/min to cf/min
Old Mar 5, 2014 | 12:04 PM
Cthulu's Avatar
Default Formula for lb/min to cf/min
Anyone have the formula for converting lb/min to cf/min?
Playing around with HPtuners logging and trying to calculate actual current FE at a given RPM. For this to work though I need the actual engine intake in CFM and not the lb/min that HPtuners is giving.
Thanks
Old Mar 5, 2014 | 12:10 PM
Iam Broke's Avatar
Found this from Google... looks like you need to compensate for temperature though.
Re: Converting in lbs per min to CFM ??
by Robert Fogt on 09/09/05 at 01:22:39
Dry air has a density of 13.076307480840681 cubic feet per pound
Dry air at 0ºC has a density of 12.417423770565761 cubic feet per pound.
pounds/minute * cubic feet/pound = cubic feet/minute
So just take whatever conversion factor from above, and multiply it by your pounds/minute value to get cubic feet per minute.
Old Mar 5, 2014 | 12:23 PM
Cthulu's Avatar
Hmm, so I need to multiply by air density.
I have KPA logged as well so
25.321 lb\min * (98kpa * 0.14503773773020923 psi) = 359.9050545925295 CFM
Cool. Thanks!
Old Mar 6, 2014 | 05:30 AM
nikon1999's Avatar
There is a conversion tool built into hptuners
