help with BCM(s)
Old Mar 29, 2014 | 09:16 AM
toplessHO's Avatar
Default help with BCM(s)
hope this is the right section,dont see one devoted specific to body control module
got a couple BCMs that would like to modify
dealer is clueless as to which ones can be reprogrammed and which ones cant.
But they would be glad to try for $105 hr.
have access to a techII and have tried to get "in" but says locked.
Ive heard that newer BCMs can be reflashed but have no idea if these can be
08 TBSS 25802312
03 TB 15065293
03 S10 15081796
Old Mar 29, 2014 | 07:07 PM
ND2RACE's Avatar
Well I'm a GM technician, I'm not sure about each BCM specifically, but there's no real way of modding them. You can change options and features in most of the newer ones, but for the most part when the BCM is new it gets programmed to the vehicle and locked. I haven't tried to do any more with a BCM then I need to at work so if there is some backwards tricks to them I don't know what it is.
Old Mar 29, 2014 | 10:08 PM
toplessHO's Avatar
OK by modding I mean adding RPOs to them
and or changing VINs
Old Apr 2, 2014 | 04:08 PM
toplessHO's Avatar
anyone?
Old Apr 4, 2014 | 09:05 AM
toplessHO's Avatar
why is the BCM such a mystery?
surely someone has reflashed one
Old Apr 6, 2014 | 08:16 PM
ND2RACE's Avatar
All I've ever done to a BCM is flash it and perform set-up on them. Once they are flashed the VIN is locked to them as far as I know. Some of them can have options changed, but for the most part the newer ones only have a couple options if any because in the last 4-5 years everything has gone to getting flashed based on VIN. The older ones where options could be changed with a tech 2 weren't around for very long. Working at the dealer it's the norm to tell someone with a used BCM to take a hike, so i have never even tried to change one once it's been flashed once, they are not supposed to be reflashable, thats the GM answer anyway.
Old Apr 13, 2014 | 09:36 AM
toplessHO's Avatar
all the info is stored on a eprom chip
some models have an eeprom chip which can be reflashed
if anyone knows how the info is coded on this chip please LMK thanks
Old Apr 19, 2014 | 02:23 PM
toplessHO's Avatar
Ne 1?
Old May 11, 2014 | 08:37 AM
toplessHO's Avatar
Well Ive had 2 guys tell me they can do it or knows someone who can then they vanish..
Anyone have input on this? It must be a national treasure its so closely guarded.
Old May 22, 2014 | 08:32 PM
toplessHO's Avatar
still looking
Old Jul 24, 2014 | 01:30 PM
Nak's Avatar
Nak
These guys claim to be able to program BCMs. I've not tried them yet, so I can't vouch for them.
http://www.whiteautoandmedia.com/ind...d=46&Itemid=57
Old Oct 19, 2014 | 09:42 PM
toplessHO's Avatar
anyone else know anything?
Old Oct 29, 2014 | 06:41 PM
toplessHO's Avatar
still looking
I cant believe that no one here knows anything about BCMs
Old Oct 30, 2014 | 08:27 AM
bigmandengo's Avatar
Also interested in this. Could be very useful for gen 4 swapped vehicles.
Old Dec 29, 2014 | 05:39 PM
toplessHO's Avatar
Im still amazed that no one has even tried to work on these
Old Dec 31, 2014 | 10:45 AM
LSX Power Tuning's Avatar
I have used him in the past, he is good.
Have you contacted the guy in the above link?
Old Dec 31, 2014 | 03:58 PM
toplessHO's Avatar
PM sent
Old Jan 10, 2015 | 08:51 AM
toplessHO's Avatar
still looking for someone that speaks BCM
Old Jan 12, 2015 | 08:47 PM
01WS6/tamu's Avatar
What are you trying to do. Every platforms BCM is programmed differently depending on the vehicle it is out of some are one time and can't be reflashed while others can be reflashed using different VINS but it must be from the same vehicle year model and line or you can brick it just like a PCM. Pretty much BCM is programmed using the VIN for the vehicle in which it belongs. The VIN has the RPO codes for that vehicles various modules contained in GM TIS 2 web and program modules using GM MDI module. You cannot I repeat cannot just ***** nilly add and delete RPO codes because you want to. There are some instances where it gives you ability to choose a few limited options regarding minor options such as this mirror type or that. But thats about all you can do.
Old Jan 15, 2015 | 06:39 PM
toplessHO's Avatar
I have a BCM from a TB SS and need to change the VIN in it to match entertainment system.
