what does all the live data from Diablosport mean?
Old May 15, 2004 | 01:16 AM
skippytheloon's Avatar
Default what does all the live data from Diablosport mean?
I get the obvious stuff, like kr and iat readings...but...
1. is there any writeups covering what my LTFTs B1, B2, etc..should be at??
2. How do I tell if I'm running lean/rich and what else should I watch for?
3. Last of all, what should I do to the diablo tune when I add a 100hp dry shot of NOS?
Thanks,
Kyle
Old May 15, 2004 | 03:02 PM
jimmyblue's Avatar
Moderator
Predator canned tune adds about 6 degrees of
spark. It gives you +/-10% adjust, or roughly
+/- 3 degrees. If you go by the -2 degrees per
100 shot rule of thumb (check?) you would
probably want to dial back to -10% if you are
close to ping at +0%, or -15% from whatever
your comfortable post-tune adjust is at. Also
most people enrich for nitrous, you might want
to jack the PE up a little so you get some
cushion there.
If you're working your way into it then spark full
negative, PE full positive, and you'll be easing out
from the safest available position.
