lean condition
Old Apr 8, 2014 | 04:00 PM
LsoneGT's Avatar
Default lean condition
I have a stock internal ls1, only mods are lts, vic jr intake, aarons elbow and a 92k tb. I have a lc1 wideband and on startup it is around 14-15 then immediately shoots up in the 18-20 range. Would any of those mods cause that lean issue? Just curious before I start adding fuel. Thanks
Old Apr 8, 2014 | 08:26 PM
jimmyblue's Avatar
Moderator
AIR pump may be active and jacking the readings.
Old Apr 9, 2014 | 06:40 AM
LsoneGT's Avatar
Thanks for the reply, I thought it was disabled but it was set at 14. I set it to 284° and ill load the tune in a few and see what happens. I dont have a AIR pump on the car so not sure if it matters
Old Apr 9, 2014 | 10:29 AM
jimmyblue's Avatar
Moderator
Well, if it's not there then it doesn't. Description said
"only mods..." and did not mention.
You might look to the NBO2s for verification. My LM-1
freaks out after cranking drops voltage and takes a
while to come back around and produce the right output.
Any cold misfiring / incomplete fuel vaporization can also
bump up indicated AFR.
Old Apr 9, 2014 | 11:15 AM
LsoneGT's Avatar
Sorry for the misunderstanding, my fuel trims and nb02 readings seem fine.
