Engine to Dash Pinouts
Old May 16, 2004 | 03:47 AM
Knyghtmare's Avatar
Default Engine to Dash Pinouts
I am looking for the pinouts of the 2 plugs from the Engine harness that go through the firewall into the car and plug into the Dash harness. Thanks a lot. Need ASAP, in the middle of the wiring process. TIA.
Oh yeah, looking for a harness 99-02. My harness is actually an 02. Thanks.
Old May 16, 2004 | 07:42 AM
crainholio's Avatar
There is only one useable dash wire...the oil pressure gauge. The 4th gen feeds serial data to the other gauges, so your 3rd gen can't use that.
You can get a horribly inaccurate tach signal (4cyl waveform) from the traction control pin on one of the C100/C101/C105 connectors, don't recall which offhand.
VSS signal may be useable, I haven't gotten that far yet but it looked like I could reuse the VSS output from the PCM (cruise control, 4K pulse/mi?) for my speedometer.
