Starting playing w/ HPT again, after update LTFT bar gauge issue
Previously my LTFT bar gauges were set with limits of 0 to -10 and the gauge would read from the bottom up. Meaning that as my LTFT would get more negative the bar would go up from the bottom (0). After installing the 2.24 update It goes from the top down. Even is I reverse the min/max location. Another oddity is if I set the max to -10 and min to 0 I get a red alert for my range of 0-15 indicating level 3 (red) It is hard to explain but I have a screen shot showing where I changed the mix/max location. One LTFT w/ a max of -10 and a min of 0 and the other LTFT reversed w/ a 0 min and -10 max. You'll notice it won't even display any data for LTFT Bank2 (Right -1.6 figure) when I do this. Not sure if something has changed in the newer versions and this isn't possible anymore but perhaps someone can assist
