MAF Question
Old Jun 2, 2014 | 10:25 PM
WAMort's Avatar
Default MAF Question
Quick question, I am removing a GM 25168491 MAF and replacing it with a ACDelco 15900023 MAF. Will I need to get the PCM re-tuned to make it work correctly?
Old Jun 3, 2014 | 01:07 PM
codyvette's Avatar
I am sure the best of the best will chime in but my .02 is that the original needs a tune to work correctly.
Old Jun 3, 2014 | 03:40 PM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Is it a direct replacement piece?
It will be pretty easy to tell if it needs tune, as the fuel trims will be out of line with the new MAF if it uses a different output curve.
Old Jun 3, 2014 | 07:44 PM
WAMort's Avatar
Thanks for the replies, I will hook it up and see what happens
