Need help diagnosing my LS1
Old Jul 10, 2014 | 03:10 PM
BigBadBandit86's Avatar
What is the psi on the stock injectors? #1 is showing a dead miss when it starts to run rough. It's going lean trying to add fuel when the misfire starts.
Old Jul 16, 2014 | 07:22 PM
Put the car under a Snap-on diag machine. Found out one of the 02 sensors was bad. It was causing Cyl 1 to have a dead miss. Swapped the 02 to bank 2 and the problem followed to cyl 6. Took it out and put an old 02 I had saved from having this issue before and the missfire went away.
