Seafoam threw a p0327 on my 98 t/a
So I seafoamed thru the main vacuum hose via brake booster... car was fine to begin with just did it for ***** n giggles before I change my plugs. Car is tuned and has the sensitivity for knock sensors turned down, but not off. After driving for about 10 min, the SES popped on. I pulled the code up with my hand held diablo and then erased it. Started the car up back to back, no problems. I'm changing my plugs bc they are a tad dirty, but I've been having cold start problems like if my fuel pump was going bad, but i have plenty of psi. Car did sit for 2 weeks and battery had been weak enough to die and had to get a replacement (I thought that was the could start issue, a weak battery, but not the case here)
SO... my question really, has anyone caused a knock sensor issue from seafoaming their car?
