Gen III Flex fuel Write-up
Most of the pics I've seen on Flex fuel conversions just have them dangling off the fuel lines. Do the ones without mounting holes snap into a bracket, or what? I see a few 3d printed brackets on Etsy or eBay, but how does GM do it? If I'm pulling one at the JY, I assume there will be a bracket for it?
Jay
Are factory O2 sensors needed for the AFR change or will the PCM sort out the required AFR target dependant on what % ethanol content from flex fuel sensor using the new tuned VE table for 98 fuel?
any info would be greatly appreciated.
You just need to make sure that your VE tables are dead on. The flexfuel sensor is what will determine what ratio you need to be at, the rest is calculated by the tables. o2 sensors will simply allow for adjustments during driving.
I've had tons of experience in the past with 0411 ECUs and similar setups and E38s, etc...
I have a couple of things I was going to try, but right now I tried a 2004 Tahoe and 2005 Express van file, but the TACH does not work.
I understand the tach on these cars is now operating off of Class 2 Serial instead of a tach wire.
I am going to try segment swapping everything from a 2005 5.3 Avalanche or even just flashing an Avalanche file instead. Or try a 2004 CTS-V file.
I assume that 2004 Tahoe and 2005 Express van do not send RPM over Class 2 and this is why the tach won't work?
I can always put LT1 gauges in and wire in what's needed but before I start doing write Entires 2 more times, I wanted to check if anyone else has ran into a "no tach" situation.
I don't need Auto controls, so I'm assuming CTS-V file would still work as long as its in a P59 with IAC drivers, since the OS appears to control IAC in it. I also downloaded a 2006 Hummer file which I'll try since its been suggested in this thread
Thanks in advance!
And tell me what you got. I'll try tomorrow, because I was on P59 since 2018, but with an A4, now i'm M6 since saturday and my Cruise doesn't work too.
Tried Blue 32 like original P411 - > Doesn't Work
I relocated to the Blue 33 like the GTO 2004, I'll see if it works when I came back from work.
EDIT: Don't work on Blue 33 too.
