Upgraded to latest version of HP tuners - Now missing Ignition Timing Advance in Scan
Old Jul 11, 2014 | 10:33 AM
00Vette04GTO's Avatar
Default Upgraded to latest version of HP tuners - Now missing Ignition Timing Advance in Scan
Hey guys,
I posted this over at HP tuners site, but realized they are out until the 21st, so thought maybe someone here might have an idea.
I recently upgraded HP tuners to the latest version on my laptop, and now when scanning my 2000 C5 the Ignition Timing Advance is now coming up as an unsupported parameter.
I have tried to close, reboot, even reflashed the car... And am currently at a loss. I have also tried to reconfigure the histograms and tables, with no luck.
Added: Have also clear last used vehicle, in which case it shows back up in the table until I connect to the car.
I have not performed a write entire, but had not performed once since my OS update. The problem just presented after upgrading.
Any ideas??
-Mike
Old Jul 11, 2014 | 01:02 PM
Since I have seen this listed in other forums with no answers -
I received a reply from Bill @ HP Tuners and it solved my issue:
close all programs
go to your documents-hptuners-vcm scanner-vehicles folder and delete all the .os files in this folder
close folder
reopen scanner
reconnect
vcm will repoll for the available pids and should fix your issue.
Old Jul 11, 2014 | 02:48 PM
jimmyblue's Avatar
Moderator
Thanks for posting the solution.
