How do you hold 3rd gear
Old Jul 26, 2014 | 08:25 PM
Monte4ever's Avatar
Default How do you hold 3rd gear
I'm trying to do some WOT tuning and want the trans to stay in 3rd gear while I roll into the throttle. However, when I get to a certain rpm and TPS% the trans downshifts into 2nd. I tried changing my Part throttle Shift tables but it still down shifts. Can someone point me in the right direction on how to hold 3rd gear. My OS is a 2002 Camaro (156).
Old Jul 26, 2014 | 08:37 PM
2xLS1's Avatar
Use the bidirectional scanner trans gear select.
Old Jul 26, 2014 | 09:35 PM
redtan's Avatar
In the 3-2 downshift set the highest mph low and make sure you are above that speed. It will not downshift.
There's two tables, WOT and part throttle and they should match.
Old Jul 27, 2014 | 06:29 AM
Monte4ever's Avatar
Ok thanks. I'll give it a try.
