versa fueler help
Old Jul 27, 2014 | 02:46 PM
97_C5's Avatar
Default versa fueler help
wiring a versa fueler into a 99-02 truck harness which wire do i splice into, there is a pink wire that goes to every one and the other wire varies in color from cylinder to cylinder. thanks
Old Jul 28, 2014 | 12:57 AM
Blown06's Avatar
8 Second Truck Club
You splice into the "other" wire. Not the pink one.
the pink wire is the +12v switched wire, they all go the same place (power source). The other wires are the ones that go to the pcm. The pcm grounds this wire to fire the injector.
Old Jul 28, 2014 | 12:01 PM
97_C5's Avatar
Alright thank you
