TB screw
the idle program. If not the TPS voltage will be high
and some stuff may be not so stoplight-friendly. The
flip side is that if they jacked with the hardware, then
maybe their tune is not as complete as it ought to be.
That doesn't look like so big a cam that idle can't be
fixed by proper tune. Tuning against improper mechanical
blade position is not a proper tune. But whether it's an
improper blade position, is all about TPS voltage and
blade bind. I believe you want the blade stop screw,
rather than blade-body interference, to set the closed
position (no wear, no crust-up snagging etc.). Measure
TPS (blue to black) wire voltage at idle, looking for
something under 0.65V on a DVM or scanning tool.
A 0% TPS interpreted reading is OK too.
The "cruise control effect" may be a tuning artifact or
may go away with idle relearn, and unrelated to the
stop screw, too.
