alternator help
Old Aug 14, 2014 | 10:40 PM
LSjim's Avatar
Default alternator help
So I have a 2002 camaro pcm and a psi wiring harness for a standalone ls1 fbody accessories. So my question is I am using a 2006 corvette alternator now and it's not charging right I either get nothing or 15-18 volts.. I have tried the "f" and "l" terminals and a 470 ohm resistor
Old Aug 15, 2014 | 12:09 AM
MontecarloDrag's Avatar
A 99-02 LS1 PCM can't control a Gen4 alternator. The wiring and control signals are different.
A 06 Vette alternator needs a pulse modulated signal to control the charging level. This signal goes to the pin "F" and can't be generated by a LS1 PCM.
It's easier to get a older alternator
Old Aug 15, 2014 | 01:19 AM
LSjim's Avatar
What year alt should I run
Old Aug 15, 2014 | 12:43 PM
LSjim's Avatar
anyone???
Old Aug 15, 2014 | 03:03 PM
LS1MCSS's Avatar
Well, you f-body accessories and f-body pcm,, sooooooo.
Old Aug 15, 2014 | 03:08 PM
"MAC"'s Avatar
Just go to auto zone and pick up an alternator for your 02 Fbody
Old Aug 15, 2014 | 04:36 PM
LSjim's Avatar
cant because it has a procharger transplant kit on it and it needs to have a vette alternator due to bracketing
Old Aug 15, 2014 | 05:07 PM
"MAC"'s Avatar
then buy a ls1 corvette alternator
