Idle wants to bounce and surge as motor warms up
#81
You may be surprised what it does going from 950 to 850. I'm running an SNS stage 3 cam which is pretty similar to yours. I had it pretty smooth at one time too, but I made some changes (one being idle dropped to 850 from 950) and now it sounds fantastic. I have a few vids in the new cams from Tick thread in the internal section. I'm running tsp true duals and it's LOUD
#83
I had mine running real smooth around 31 degrees or so, iirc. I'm pretty sure I'm at 24 right now. It still surges a little, but sounds great and runs pretty damn good. I'm still not done with it, but merely taking a little break before I fry my brain. It's all I've done since putting the cam in two weeks a go. It was all new to me as well, it's been quite the learning experience to put it bluntly lol
#85
Jake, Sorry to Hijack this thread but I see you have a FAST TB. I have the 92mm FAST TB. When I put it on the FAST 92 intake It didnt come with the bolt that goes on the back of the TB towards the top. FAST told me I need to leave this open but on the stock one it has a bolt through it. That confuses me... What should I do??
Scott-
Scott-
#87
Yes. I have the four bolted to the front on the manifold but then on the back side of the tb there is a fifth hole near the top. The bolt goes in through the intake then into the tb. The stock tb has a bolt there. I just don't wanna plug it if it's not necessary. And I don't want it to mess with the tune being done tomorrow.
