Odd stalling issue
Old Sep 23, 2014 | 04:51 PM
Mean87SS's Avatar
Default Odd stalling issue
Car: 2001 Camaro A4
Mods: Lid, longtubes, cam (232/234 617/598 112+2) SS3600 converter, 3.42 gears.
Car is tuned, idles fine. While coming to a stop car will sometimes stall for no reason. Not a quick closure of the TB like coming from a burnout, slow driving then a stop.
Ideas?
Old Sep 24, 2014 | 10:49 AM
01MAROONz2890's Avatar
was this present immediately after the cam and converter swap or did it just start happening?
Old Sep 24, 2014 | 03:47 PM
EFX_DAVE's Avatar
Post the tune?
Old Sep 24, 2014 | 05:45 PM
blk2001z28's Avatar
After cam swap .. Converter been in car for 3+ yrs
Old Sep 24, 2014 | 06:48 PM
redtan's Avatar
I have the same thing sometimes, it's more pronounced when I come to a complete stop really quickly. So far haven't figured out what's doing that.
Old Sep 24, 2014 | 06:51 PM
jimmyblue's Avatar
Moderator
On some model*year factory files I've seen really kooky
throttle cracker maps which have a "divot" near return-
to-idle which could be a destabilizing "event" if you step
in it and the motor is already struggling a bit. With the
big cam I'd expect idle and transition-to-idle to need a
lot of fine fiddling.
In the attached pic, note how many cells of the cracker
give zero help as you approach idle (left side, stock '02
F-body tune file) and how the airflow adder is jerked
around variably by how you approach 0,0. This could be
a "stimulus" the idle RPM is forced to react to, and that
loop is a soggy piece of **** even when you don't challenge
it with a cam and bad tune data elsewhere (jacked VE,
false trimming, etc.).
On the right is where my setup sits, a smooth and sane
"weaning" as you approach 0,0 from any direction. I
get no idle undershoot except in reverse, a little (a
common issue, I have yet to see anyone say why but
many say "me too").
Have a look at this feature, in your tune.
<note: for some reason my nice high resolution .png file
is turned into a low res crappy .jpg by the site; if you
need a better copy let me know where to email it>
Old Sep 24, 2014 | 06:57 PM
redtan's Avatar
Jimmy, what would be the tables to look at for a DBW throttle?
Old Sep 24, 2014 | 08:33 PM
blk2001z28's Avatar
Issue is at normal slow down .. Fast slow down has been good .. I can barely see the pics on my phone .. Pm sent wit my email
 Michael S. Palmer
Old Sep 24, 2014 | 11:43 PM
EFX_DAVE's Avatar
If it's ever since the cam install I'd definitely say tune related.
Old Sep 25, 2014 | 09:29 AM
moehorsepower's Avatar
Look at your throttle follower tables
Old Sep 21, 2015 | 11:56 PM
blk2001z28's Avatar
Figured it out .. My throttle body was over ported .. There was a paper thin gap all the way around the throttle body blade to the walls
