Timing going to zero on launch, M6 no traction control
On launch it starts to wheel hop so we had to pedal it and its seems like the frame after we're high tps% and then let out before getting back on the gas, it drops timing to nothing. Hence, the thought of DFCO or something else that would do that.Zero knock and burst knock table is set to pull zero degrees. Car is an M6. From what I gather, the car was pulling somewhere between 6-8 degrees. Initially I saw the timing was going to single digits and realized it was in the high g/cyl low rpm area of the main octane spark table. I fixed that and now it still seems to be dropping to zero if its peddled. If you floor it from a 1mph rolling start so it doesnt wheel hop, then we dont see the timing drop.
NOTE: BEFORE LOOKING AT THE TUNE FILE, CHANGE THE EXTENSION TO .CTZ SINCE LS1TECH DOESN'T ALLOW THE CTZ EXTENSION THAT THE NEW EFI LIVE TUNE FILES HAVE.
I'd put them all in the log and see what is active.
Oops, EFI live. Maybe it will do the same.
Corvette? Is all the trans abuse and tq management removed?
Thats the plan for next time, but was hoping someone can see the log and tune and tell me why. Its an Fbody, M6 so no trans abuse and torque management is zero'd out.
Dont take this the wrong way but you have more of a suspension issue than a tuning issue IMO. If your letting out that much on a pass like the log shows then your ET isnt going to be close to what should anyways.
